sabst79 »
https://forums.nicoclub.com/sabst79-u103678.html
Fri Aug 15, 2008 1:00 am
Hello, Im new to the forums and have an '02 SL, and basically know nothing about cars. For the past year my heat has not been working unless the car is moving and during stop and go traffic it gets really cold. I've been to my mechanic at least 3 times and he's always bled the car and refilled the coolant and that helped for a few months, but then it would go back to cold. He says he can't find a leak, but I can hear some splashing/gurgling sound in my car and sometimes I can smell the coolant.
Im also having the same clutch problems that a few people have posted about. It gets depressed and stays in, and doesnt come out, if I let it go too long, I can't get it into gear. Usually the fluid is low, and that gets refilled, but again, can't find a leak. This has happened twice in the past year.
Thankfully my mechanic doesn't charge me for the bleeding and refilling of fluids, otherwise I'd be broke right now.
I've also noticed that Im driving at higher RPMs than what it used to be, usually its around 3000 now instead of 2000, can all these problems be related? has anyone found a permanent solution to any or all of these?
thank you.
