moredunes720 »
https://forums.nicoclub.com/moredunes720-u138333.html
Mon Jul 27, 2009 7:59 pm
i did that, too., just did not cut the sides off like yours. just havn't gotten it running again yet. Total failure as a mechanic. I changed out the master cylinder, tried to bleed it, found out it has a damper thing, so i bled both. Yet it still makes a frightening noise when I release the clutch pedal. Kind of a hard knock that comes from the transmission somewheres. It used to intermittently make this noise, hence the master cylinder change. I am going to try bleeding it again but....not sure why it got worse instead of better. I guess this means the truck is really an '86?
