converting to rack and pinion?
Discussion forum for the venerable 510, and its non-US counterparts, the Datsun 1600 and Bluebird.
sclay115
has it/can it be done? thinking of doing a newer nissan motor swap and the obvious clearance issue with the steering box could be solved with a manual rack, however, i wouldn't even know where to start...anyone have any info?
81na ZX
Car: 81 280ZX, 69 Lotus Europa
A friend of mine put a s13 rack into his 70 510 coupe.Lots of fab work involved.
I'd assume the s130 rack would be a really close to bolt in fit. But I couldn't tell ya, I don't even have rack and pinion steering
datsunboy
Car: Datsuns
yes...people have used the S130 240Z rack before....but theres not much to gain out of it, considering the custom work involved....along with the fact that you can't lower your 510 very much using the 240Z rack ( for some reason I don't know ).Go to http://www.datsuns.com......there is a how-to article on there for the 240Z rack into 510 conversion
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
datsunboy wrote:yes...people have used the S130 240Z rack before....but theres not much to gain out of it, considering the custom work involved....along with the fact that you can't lower your 510 very much using the 240Z rack ( for some reason I don't know ).Go to http://www.datsuns.com......there is a how-to article on there for the 240Z rack into 510 conversion
S130 is a 79-83 280ZX which steers from the rear fo the front axle, the S30 is a 70-78 240z,260z,280z, they use the rack that steers from the front of the front axle
some of the early S130's actually used a steering box, most of the later models used power rack and pinion, and a very few early cars used a manual rack
and your link doesn't work
ZXR_KiD
Car: 1979 Datsun 280ZXR (yes a real ZXR)
EvilD is rightS130s with manual racks are hard to find my ZXR is equiped with one and the only other ones I've actually seen where supposedly former ZXRs aswell aside from the 1 or 2 that'll pop up on Ebay.
The S130 is slightly wider than the S30 so consider that before you rush out and get a rack that might not fit.
as for the S130 with a steering box, I've currently got the entire assembly sittin out in the garage if anyone is interested, it came out of an 80 that we did a standard power rack swapover on.
Return to “Datsun 510 / Bluebird”
