evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Mar 08, 2007 7:14 pm
Welcome to Nico!doing a full clip or simply selling you car in favor of a TT are the better methods, you can turbo the N/A but with the higher compression ratio you are more likley to preignite and trash the motor
to address some of you questons, the side mounts are nice as they do not block airflow to the radiator and they arequite capable and come on stock TT's so if you swith cars or buy a front cut you already have them no added expence, also with a front mount you need dual inlets and dual outlets with additional piping or if you stay with the side mounts you guessed it you already have the piping
radiator is the same
you dont edd an oil cooler
I am pretty sure you have to have the complete TT harness to go with the ECU, I don't think the n/a has a knock sensor
na flywheel and clutch are fineand if you get an aftermarket unit just be sure it fits your flywheel, or click the link in my sig, great people and great prices on quality aftermarket flywheels and clutches, I have had bad luck with CMDF, lasted only a short while
one piece driveshaft you'll nbeed to gett he one for the n/a the pinion flange is different
