patmcd06 wrote:Hi kmiles,
I'm about to do the Morimoto elite H1 install this week. Where did you find the directions for the install? Ive never done something like this before, but think I can pull it off. Did you have to solder any wires?
Thanks,
Pat
Hi Pat - I used the instructions on the TRS site. I purchased the bulbs, ballasts and the H1 harness from them. No need to solder anything. The thing that takes the longest is taking off the wheels, and taking out the front part of the wheel well liners and then taking out the air filter unit. I put the car on a couple of jack stands and then took my time. The only modification that I had to make was to cut the two wires that go through the grommet to connect the trigger wire connector (it connects to the two wire connectors connected to the right (driver's side bulb). I used a couple of inline 3M heat shrink butt connectors. I did not need to modify any other wires or connectors. For the battery connector, I just removed the right of the two bolts on the battery positive connector cable and put the harness connector on the bolt and tightened down nut. I also used the two grounds on top of the wheel wells to connect the ground wire on each side of the car. I tied everything down using wire ties to finish it off.
My one area of learning was placing the ballasts. I was one of the unlucky ones who purchased the new DSP ballasts that failed after about 30 days of use. I had found what I thought was the best place and very well concealed. That would have been fine if I didn't have to troubleshoot and replace a couple of them, so when I reinstalled them the 2nd time I put them in a location that protected them from water and made it easy to replace when they blow (basically on top of the wheel well near the ground points). My new ballasts seem to be much better and I haven't had one blow in about two months. I was very disappointed in the quality of the initial ballasts, but TRS was good about replacing them quickly.
I fully agree with IlayKol on how much better the lights are after making this change. The cutoff is sharp and I've never had anyone flash their high beams at me. My only wish was that they were as reliable as the VLEDS. The VLEDS have been rock solid with no problems.
