kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Wed Feb 02, 2011 12:54 pm
My short answer would be absolutely no, not within the realm of normal limitations (time, money, practicality).
Just look at one aspect, the CVT transmission - you'd have to replace this with a completely new AWD unit to accomodate the rear drive shaft to the rear wheels, this alone is around $5000, then you're still without any of rear-drive components including the drive shaft, rear differential and a long list of additional drive components.
The computer programming (TCM and ECM) is different for AWD and I'm not sure if it could be simply reprogrammed or require replacement, and a whole long list of other items like the fuel tank - it's different on AWD Rogue than FWD so it would have to be replaced.
If you had enough cash I suppose anything is possible in life, but if you want AWD that bad why would you consider spending $10,000+ dollars trying to upgrade your current Rogue when you could just trade it in on a new AWD model for much less, AND the new or used Rogue will have manufacturer warranty?
