Converting factory xm to sirius -- is p/n 999U9-AS006 all that i need?
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
dscottjr
As the title asks --- want to convert my 06 qx56 from factory xm to sirius. Is all i need the nissan/infiniti part number 999U9-AS006 to make the conversion happen? I'm assuming this is a plug and play tuner box that connects to an output of the radio?
Thanks!
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
I believe that is all you need, make sure your antenna has the same plug on it, but the pre-wire cable will plug into either the Sirius or XM receiver.
dscottjr
Hmm, i have no clue how to check to see if the antennas are the same except to order it. Do you have any other ideas?
Return to “Armada Forum / QX56 Forum / QX80 Forum”
