encasemyheart »
https://forums.nicoclub.com/encasemyheart-u1676.html
Wed Apr 09, 2003 6:31 am
external to internal? are you serious?
Internal gates (like the name implies) are built into the turbo, unless the turbo came stock with one you will need a whole new turbo with one built in. Even if you were able to get one built in, you would need to buy a wastegate actuator and attach it to the turbo itself with it's non-existant mounting points (since it wasn't built for one)
External gates are better performance wise and only consist of attaching it to the exhaust manifold (there should already be a flange) and I believe attaching 2 vacuum hoses. That's it.
There really is no reason in the world that I can think of to convert to internal, ESPECIALLY if you already have an external gate.
