linuxbatm wrote:But the r33 cluster is such an awesome cluster... This is extremely simple to do on a s13 cluster, i just dont know the resistance values id need, so i was wondering if anyone else had any idea.
theres a chip you can buy i believe that all UK skyline owners use and also i believe there is a write up on how to convert the km/h to mph on the r33 speedo, just google it and you can find it, cause i was considering the r33 cluster but when i found out that the s14 cluster speedo works perfectly if you have stock 4.08 diff gears and the tach is adjustable. but good luck.
