rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Wed Feb 01, 2006 4:37 am
Well, the blocks should just line up, so you will need mounts, bellhousing, transmission and driveshaft. You will also need all intake ducting as well as the intake manifold. Don't forget wiring. As far as internals, are you wanting N/A or boost? Are you using a DE or a T? If you are using a N/A motor and want to go turbo, all you really need are the pistons. The crank girlde is nice, and I bet Dee or Rafi could get one for you.
