Converting '91 King Cab to 4WD
Eukie78
Car: 1991 Hard body
1992 Pathfinder
So the frame on my '92 Pathy has finally rusted away enough as to be unsafe. Drove down to Georgia and bough a beautiful, rust-free '91 2WD automatic V6 King Cab SE. Before winter hits Michigan, I would like to have the truck converted to 4WD. I was a mechanic for eight years (10 years ago) and am not sweating the project, but would love to pick your brains and try and be properly prepared.
I just purchased a 4WD automatic transmission out of a '94 King Cab and am planning on using that along with the front suspension, diff, halfshafts, and rear axle out of my 92 Pathfinder. I realize that I need to go back to the scrap yard and buy the the rear driveshaft as well. Should these parts all mesh together well? Any help is appreciated as I have been trying to research this for a week or so and have found only limited results.
whomadewho
Car: 1997 Nissan pickup
Anything is possible. Hate to sound negative - What about the cross members. If you have children you might consider buying a season ticket for the movies or a membership at the pool. Before you're finished you will be on a first name bases with God and not in a positive way. There is a lot of 2wd & 4 wd parts that will not interchange. The electronics and emissions will also be a challenge.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
it's not gonna work without major fabrication. 2wd and 4wd frames are different. stuff won't just bolt in.
you're much better off finding another 4wd truck unless you want to do a Solid axle swap or similar.
Eukie78
Car: 1991 Hard body
1992 Pathfinder
Truck is in too beautiful shape to not do it (gotta be 4x4 for our winters). This is the kind of info I'm looking for because I was thinking it would be a reasonably easily bolt in. Not afraid of heavy fabrication. With frame mods, should I be cool using front/rear diffs from Pathfinder with this 94 king cab 4x4 trans? Probably gonna swap the trans, and only the rear diff, then troubleshoot. Then, on to the front.
whomadewho
Whatever decision you make is going to require a lot of time & patience. The drawback with fabrication is the vehicle is going to be less sellable. The way the the frame was designed (closed) this is going to make fabrication far more difficult. . I totally agree with Desert Rat . A 4x4 donor will also give you access to the extra wiring electronics & sensors needed to make this possible. Watch the difs. Ratios. This could result in a inaccurate speedometer.
Desert Rat
2017 Frontier 4.0
2008 Boulevard C90T
Yes, the diff ratios will be significantly off between a 2wd and 4wd, and the 2wd truck uses a much smaller rear end than the 4wd truck does.
On that old a truck, there's not much electronics to worry about. But if you were wanting to swap over a 2wd truck to 4wd, I'd just scrap all the IFS stuff and do a basic solid axle swap.
Nissan4wheelers.com has gobs of tech articles on solid axle swaps in the skidplate alley forum. Might be a good place to start doing some reading to get ideas. Lots of different suspension configurations to choose from.
