ishkabibble wrote:It might not be a "leak". The top of the car experiences lift (think of a plane wing) when the car is in motion, and if the fabric has stretched out, it creates a bubble.
I had the same issue, though probably not as bad as yours. I redyed my top with Renovo and then treated it with 303 Convertible Top Protectant and the fabric tightened back up after it dried out.
I too have the bubble, and ish is right about the airflow across the top of it. The more surface area the air has to pass over, the faster it has to go relative to going across a flat surface, thus creating lift, thus creating our lovely bubble.
I'm looking into a possible solution for mine, as the velcro across the rear window has completly deteriorated. I think If I sew some nice industrial strength stuff across it and get it to pull tight it will help out tremendously.
also, if you want to see what it looks like bubbled up, just turn on the fan full blast, get out, and shut the door.
I'll try and get some before and after pics of my experiment.
