IslandStyle »
https://forums.nicoclub.com/islandstyle-u36903.html
Thu Aug 02, 2007 1:56 pm
The piece I'm talking about is highlighted in RED, and it is destroyed! Under the visor mounts it has just shattered apart and water pours out of it, it's all cracked around the dome light which also leaks. The other areas are in yellow on that "bar" like piece that outlines the plastic piece. Every yellow ring I highlighted is where I've stuffed silicone and epoxy to keep it from leaking and falling apart LOL!
Here's another issue: The yellow ring reveals a hole (missing trim piece) and all the original silicone inside is deteriorated (I just plugged it with fresh 3M caulk ) but along the top trim piece highlighted in RED there is bodyrot that is slightly visible if you wedge a screwdriver in there and pry it up just enough to see. I want to take it off so I can use body filler and repair underneath it, but I couldn't yet figure out how it comes off.
The last leaking, and one of the WORST ones, is these parts where the little strips of weatherstripping are. The weather stripping doesn't even make it to both ends, which leads me to believe that maybe they were generic aftermarket cuts that don't fit well? Because you can just simply slide them back and forth, so I don't think they are the right ones. Either way, inbetween them is like a faucet in a rainstorm .
Honestly, I love this car and just how rare it is keeps me loving it more. I've had offers on two occasions thrown to me from another car at a red light But this car PISSES ME OFF!!! Everything else that was wrong I was able to fix or am getting to it. But this leak thing is killing me because I'm in Florida, so when it rains, IT RAAAAAAAIIIIINNNNNSSSSS!!!But this car had only 86,000 miles when I bought it over 2years ago, and now only has 101,000. It's a great car and I love it. So I'm not giving up at everything that's breaking on it regardless of how impossible the parts are to get
