Convertible leak
Harman850T5
Car: 2003 350z
I've found two spots that are leaking on the car. The driver side window doesn't touch the top in the back part so there is a little open spot for water to get in. There is the same thing on the passenger rear quarter window.
Is there a cheap fix I can do for this? I'm thinking about getting some double sided sticky tape or a little bit of foam to put in there.
Other than that there are no leaks. Thank you for your help.
jamesblonde82
Car: 1992 Nissan 240SX convertible RIP 5/10/07
1993 Nissan 240SX convertible
how easy is it for you to latch your top? might just need to tighten it up.
94_240sx
Car: 94_240SX
I adjusted the latches by tightening up the hooks. I also climbed up to the roof and stepped on the rails here and there. Worked like a chram.
jamesblonde82
hey thats also a good idea. you didn't actually get on the roof did you though? i have to hold down the top with my hand while i latch it, but it keeps it sealed very well, no leaks.
94_240sx
Car: 94_240SX
I'm talking about permanant solution here. Yes, I actually climed up on the roof and stepped on rails, so I can bend them. Some of my rails were crooked when I bought it. If you push it down too much, lay down on the seat and push up with your feet.
Harman850T5
Car: 2003 350z
I have to hold it down when I clamp it. I've read somewhere that the windows on some other types of convertibles come off track a little bit, and they need to be adjusted.
I may have to try the standing on the roof thing. but with someone who doesn't weigh 210 pounds.
94_240sx
Car: 94_240SX
Harman850T5 wrote:I have to hold it down when I clamp it. I've read somewhere that the windows on some other types of convertibles come off track a little bit, and they need to be adjusted.
You need to check quarter windows first then. Look for broken clips on the rails.
ishkabibble
Car: 1992 Nissan NX2000 hardtop
1993 Nissan NX2000 t-top
1997 Infiniti I30t
For the door window, you can adjust the position of the regulator and the stops on the window. Also be sure that the window isn't catching on the windshield frame when you close the door.
