Postby
Ihiryu »
https://forums.nicoclub.com/ihiryu-u35607.htmlWed May 30, 2007 5:46 pm
Welcome to the broken vert top arm club. Mine is also broken....I tried to get it welded, but the welds don't stick, and I tried to put two bolts through my arm (at the base of the top by the rear windows) and it snapped it even worse....if you find out something before i do LMK.
Postby
Hijacker »
https://forums.nicoclub.com/hijacker-u9394.htmlThu May 31, 2007 3:18 am
AZhitman wrote:It'll weld - Needs to be done by a competent welder / fabricator though.
agreed. The metal is fairly thick and sturdy, so it should weld. You just need to prep it up. Get rid of that rust and paint and take it to someone experienced.
