Where did you find the prices($173)? I called to nissanpartswarehouse.comNative2PS wrote:I got the bumper from nissanpartswarehouse.com, part # F2023-1A41H, they charged me $173 for the bumper
Looks perfect but what was the problem with custom grill?Native2PS wrote:Ok, its finally done! the mesh grill on the top didnt work out, so I had to break down and spend $500 on the OEM grill, but overall, I like the way it turned out.
Native2PS wrote:Ok, its finally done! the mesh grill on the top didnt work out, so I had to break down and spend $500 on the OEM grill, but overall, I like the way it turned out. I had to retrofit the foglights on because they are not the same even though the local dealer said that they were. I also installed led fog lights as you see in one of the pics. Overall, it cost much more than I wanted to spend, but I like the looks of the krom front much better than the regular front, so it was worth it!
because of the curve, the mesh was hard to bend, and it just didnt look rightLeo2005 wrote:Looks perfect but what was the problem with custom grill?Native2PS wrote:Ok, its finally done! the mesh grill on the top didnt work out, so I had to break down and spend $500 on the OEM grill, but overall, I like the way it turned out.
Score thanks for that! Any idea what the part number is for the exhaust, too? I'm interest in doing a rear-only conversion on mine to get perfect symmetry (Since that'd be cheaper and easier than doing a custom dual-exhaust job).philipa_240sx wrote:So to summarize:
KROM edition conversion for 2008-2010 Nissan Rogue:
Front bumper Fascia # F2023-1A41H, $482
Grille # F2310-1A41A, $417
Nissan Grille Emblem # 62890-5U600, $30
Rear Bumper Fascia # 50221A41H, $565
Total: $1494
Source http://www.everythingnissan.com/
Adding this to the FAQ...
Native2PS, anything else you have noticed that does not fit the Krom bumper? What about the splash shield under the bumper?Native2PS wrote:I had to retrofit the fogs because the Krom bumper uses a different set of fogs...
On the stock bumper... it's all one piece. The black 'trim' you are referring to is just painted another color.harryg wrote:also is the bottom part included (the litte black part on the bottom of the bumper)
I was referring to this kind of plastic piece like the one found on our rogues (where the muffler tip is...goes along the entire length of the bumper)philipa_240sx wrote:On the stock bumper... it's all one piece. The black 'trim' you are referring to is just painted another color.harryg wrote:also is the bottom part included (the litte black part on the bottom of the bumper)
There is still the muffler to deal with too, that's the black piece that you see hanging below the bumper.
