Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Jun 04, 2004 5:23 am
for the fronts, you'll need an S14 knuckle, S14 5 lug hub, and an S14 ball joint to press into your LCA. Also, you'll need the strut bolts. They're a bit larger than the S13's, so you'll also have to enlarge the holes in your struts to get them to work.
as for the S14 (or Z32, the style of hub wasn't clarified) rear hubs just bolting up, i can't verify that.
