PalmerWMD »
https://forums.nicoclub.com/palmerwmd-u108.html
Tue Aug 16, 2005 8:33 am
Most people dont experience leaks anymore.
When they do happen they are generally due to a different mechanism:
A new different oil mwith different detergentsm often gets rid of some sludge, which may have assisted in sealing potentially leaking gaskets ( sludge otherwise is a very bad thing of course)
Switching to a new oil with possibly higher detergency, could produce this effect regardless of syn or not.This is a rest risk we cannot remove, if you switch to an entirely differnt line of oils (dinos are getting more and more similiar to each otehr)
So I cant promise you , you wont see leaking, but if you do, its for a differnt reason and it also means, you are dissolving depostis were you<need> them disssolved also.
Syns are geranlly safe to switch, I switched them and again with high miles vehicles (and no flush) with no leaking at all.
But then again all those vehciels were in pretty clean internally.
In summary:
Dont flush ( can cause its own problems if not done correctly) and just switch.
Fuel cleaners:
Choice 1: BG44k , generally can only be bought at stores powerful, works well, if used as directedChoice # 2 Chevron techron injector cleaner:Same active ingredient as BG44k only a lot less, so less care needs to be taken in its use .
Follow directions to the letter in both cases.
Fred..
PS: Welcome to NICO!!..
