so which is a better of the 2 oil's mentioned or should I completely change brands . Im looking to get the high miles out of this good running engine so far at 109,000 miles on it,
I must say I agree with this line of thinking. I used to change oil in cars past every 5k (km). The oil still looked almost like new and it felt very wasteful. Now I change it every six months, using conventional oil, its usually at least 10,000km I think and the oil still looks pretty good, not black. I've pulled the dipstick on lots of cars and seen tar-black oil. Even running extended intervals my oil does not approach that. Ymmv.yeldogt wrote:At 4k oil changes -- anything will work. Even the cheapest oil today is better then the stuff back in the late 90's
I have had problems with synthetic oil in the 3.5 Nissan V6 -- synthetic oil does not thicken when cold .. all three of my pathfinders and my ultimata dripped oil with synthetic.
I use the blended or high mile conventional oil in my pathfinders -- 10w/ 30 -- with a 7.5k change interval. All have gone over 175k with no engine issues.
When you change at 4k -- Im sure it is still clean ... mine at 7.5 is clean .. I feel guilty?
Yes you got it its the dripping , as far as I could look up in oil myths and tech notes they say the seals have to be made out of a material that can with stand the cleaning action of the high detergent in synthetic oils .yeldogt wrote:At 4k oil changes -- anything will work. Even the cheapest oil today is better then the stuff back in the late 90's
Some excellent threads off the top of my head on the topic, FWIW:Densetsu wrote:According to the owners manuals, for '01 and '02 synthetic is fine ("Mineral based or synthetic type oils may be used in your NISSAN vehicle."). For '03 and '04, it's not ("NISSAN does not recommend synthetic type oils but recommends mineral based oils.").
I've used M1 0W40 for the past 3 years, 7K mls OCI, now at 120K miles, and no leaks. It does use about 1 qt of oil during the 2nd half of the interval, but also used about the same with conventional with shorter OCI.yeldogt wrote:I have had problems with synthetic oil in the 3.5 Nissan V6 -- synthetic oil does not thicken when cold .. all three of my pathfinders and my ultimata dripped oil with synthetic.
Further, I wanted to use a 0w oil for a time to clear the small oil passages in the variable valve timing mechanism, and the hard to replace PCV valve. And I'm replacing the oil filter (one designed for synthetic oil use - in this case Purolator Synthetic) half way through the oil change interval (3.5k mls) to capture sludge that's clearing from prior conventional oil use.AlanAZ wrote: I've used M1 0W40 for the past 3 years, 7K mls OCI, now at 120K miles, and no leaks. It does use about 1 qt of oil during the 2nd half of the interval, but also used about the same with conventional with shorter OCI.
