I'm tired of my lights not turning on when I open the door (it gets dark at like 4PM now!). Is there any fix I can do with some switches/sensors to make it so my lights turn on for a preset time when I open the door? I'm fairly acquainted when it comes to electrical and I have the equipment to modify anything needed. Note: I want this to happen when any of the doors open, including the rear hatch.
What I would like to have in the end is a sensor in the door, either using the existing one or a new one, and a switch control in the dash. So when I open the door, the signal sets of a circuit to turn the lights on for 30 seconds, after which they will turn off. However if I need to, I can turn the switch on to turn on all the lights regardless of the door switch.
What would I need to do to achieve this. I have looked at the PDF manual and I cannot find the switch necessary to activate the lights. I also need to see if I can get something to control the timing, obviously the burned chip is what controlled it previously. c
Would I be able to resolder the burned connections making essentially a bridge over the bad connections? Could a put a fuse across this bridge making any future blows fixable at a moments notice?
