my question is what is the best way to have a "lower speed" ? I was thinking of just using resistors (with alittle bit of math) which should lower the power going through them. For example: one fan has 42ohms resistance, and the power source is of course 12v, so it uses .28amps of current (12v/42ohms that right?). so all I would have to do is make a resistance inline to the fan so that its current used is less (say maybe .15amps for low speed?)
what are the best kind of resistors to use? I dont know if the local radio shack is going to stock something that can handle that kind of current, what is your suggestion? I am willing to order stuff online.
Im only 18 and i havent even started college yet so my math might be horrably wrong... if you think Im wrong dont hesitate to give me a *possibly big push* in the right direction.
Thanks for your time almighty technical gurus
