Quote »In response to the original question, most systems that I have seen only open when the OD switch is engaged, i.e., when the pedal is all the way down. On motorcycles, I've seen the NOS hooked up to the horn switch. Pretty convenient until you need to use your horn! If you want to get any fancier, you can create a simple logic circuit from maybe $10 in parts (circuit board, common gate chips), in which you could specify what parameters lead to what event. E.g., IF pedal floored AND third gear, THEN apply NOS at 8V. It's been a while since I took a circuitry design lab, but I do know that something like this wouldn't take much time to figure out from a basic circuitry textbook. The issue then becomes one of inputs. You would need a separate input (from the vehicle, hopefully) for each parameter. Each one is either on (voltage) or off (dead).[/quote]
That is what I had in mind.Could and should you take it a step or two further and set up a board with 3 or 4 settings pe-programed,then you could change how much power you need for said occaision.Mount the switch in the glove box or storage compartment.You would need a master button to arm the whole system.That would be a sweet NOS system.:ylsuper
