cbishun wrote:thanks guys, it wasn't working because the auto up was not programmed, now fixed thanks to some research on Nico Forums...Now all 4 are working but it sucks that you cannot get them to go up as well.
You can but it is a bit of a pain. Remove the metal key from the fob and insert it in the keyhole of driver door. If you turn the key clockwise once it opens the locks, turn it a second time and hold it....the windows will open.
If you do the same thing but turn counterclockwise, the doors will lock and the windows will all go up.
