Control Arms
usislams
Car: Honda Pilot 2006
New problem,Took my car for allignment and the tech told me that it needs new upper control arms, both sides.Q: Can I get used refurb?Should I get it from dealer? Any advise and options that I may have.Any idea of cost involved.thanksShams
qship96
Car: 1996 Infiniti Q45
also known as "upper links" to us g50 owners- around 100 each thru joe by mail order. simple to install,and last 30-60k miles before needing replaced again depending on roads/ suspension/ heavy wheel & tire combos.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Check the other rubber compnents while you are looing at the suspension. Probably need more, like tension rod bushings.
SPB make some adjustable tension rods and uupper links, for more money.
