BattleRPs13 »
https://forums.nicoclub.com/battlerps13-u14898.html
Mon May 17, 2004 11:43 am
There is nothing wrong with getting one from a junkyard as long as it is straight I have done it.
Yes the ball joints are on the lower control arms. If they look bad or extremely worn then it would be a good idea to replace it while the LCA is out, because you can get someone to press it out and a new one in much easier than later down the road.
Also you may want to take a look at your tie rod it your control arm is bent there is a good chance it maybe too.
