180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sat Sep 04, 2004 8:39 am
The rear, I think you might just have to take an impact to it. It's been a while since I last mucked about there, but I do vaguely remember the ball joint causing some rotation in the joint but not to the point where I couldn't remove the nut. In removing the nut I'd just use an impact wrench if you're having that problem also might want to check on the joint too, it might have too much play in it or maybe the joint's not all the way in the knuckle on the suspect joint. Might want to hit the threads with some WD-40 or some PB Blaster a bit before going further.
