Control Arm Bushings??
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
When I go over small bumps I hear a slight thump sound which reminds me of when I had some control arm bushings crack and go bad on my previous car.
Has anybody had a similar problem?
I'm going to be putting a 350z suspension on it in the next few days and since i'm down there anyways, might as well fix this if its a problem....
Do they make upgraded bushings for these, or replace the whole arm?
Modified by tollboothwilley at 8:46 AM 1/28/2008
tollboothwilley
anyone?
G_whizz
Car: 2010 G37 Coupe Sport
hang tight Johnathon... help is coming!
I'm no expert so I emailed some other mods..
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
Whoa I have no idea either, but 350z suspension? I didn't know it could be done. . cool. . I want a g35.
C-Kwik
I haven't seen any bushing kits from the bigger US companies (Energy Suspension or Prothane). I'd suspect, you could put some together from some of their existing parts if you knew the specs you needed though.
I would be surprised if you exhibited bushing wear this soon though. I'd check it out and confirm the source of the noise before spending money on something that may not resolve the noise.
infinititech1
mileage on ur car?
tollboothwilley
117K
also in my sig below
MaximA32
Ever replace your struts and/or mounts?
tollboothwilley
I'm replacing them here in the next week.
the suspension feels solid, i only hear the noise while driving although handling hasn't changed much. Its not the bouncy effect of a bad strut so I'm just wondering if its a bushing.
I haven't changed out the mounts or struts yet...as i said, i'm going to be installing new struts/springs off a 350z in the next little while.
Would the strut mounts be a possible issue like this?
MaximA32
It could definitely be a strut mount. With 117+ k miles, I'm suprised it hasn't happened before now.
tollboothwilley
Good, i'll check into that then.
Like i said everything in the suspension feels solid but its a very tiny audible sound like a wobble for a half a sec after you go over a bump.
Hope this is the prob
thanks for the help
infinititech1
sounds possibly like upper strut mount...but hard to tell without hearing it
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
If the z suspension you are getting has strut mount, that probably will fix your problem. How many miles on the z suspension you are purchasing?
