Hey John, this is kind of another topic but I read you swapped to 350z suspension. What exactly did you swapped and why is the 350z better? (im guessing the G35's rear end should be heavier)tollboothwilley wrote:front or back suspension?
the Front suspension is much more likely to have the strut mounts go out before the control arm bushings.
I changed mine out when i swapped to the 350z suspension and it fixed that for me.
Now I've developed a clunk in the right rear of the car, which i believe is the control arm bushing.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
