Alright, thanks for the help. and i was just joking about the nerd part. I still not sure I sure comprendo 100% though.
Quote »Power is torque with rotation. Torque without rotation can't move anything. Get a 100 lb kid to stand on the end of a 10 ft diving board, and he has created 1000 ft-lbs of torque at the base of the diving board. The diving board isn't about going to go anywhere though.[/quote]
I know they will still create horsepower, but is it a number that is actually important in how fast the car is going to accelerate? If you already answered this I'm sorry, I must not be understanding any of this at all.
Quote »We are used to engines where the torque curve peaks before the power curve peaks. The only reason peak torque is lower than peak power in cars is because they must operate with discreet gear ratios, and thus require some kind of power band in order for them to actually have some range of engine speed to accelerate in each gear. In a CVT, there is no need for such a power band. In a CVT, the engine's peak torque and peak power RPMs are designed to be equal. The engine will have absolutely no low end grunt, but CVTs don't care about low end grunt because it never needs to let the RPMs drop for gear changes. [/quote]
Won't peak torque alwasy occur before peak horsepower, due to the mathematics
And one last question.... will a car(with a cvt and all other factors equal) that makes a peak torque of say 150lb/ft at 3000rpm accelerate at the same rate of a car that 150lb/ft at 6000rpm. The way I'm comprending it the second example would accerlate faster becuase it could better manipulate gears. Or am I wrong on this too. Should even compare rpms when talking at about torque, since that would be just like comparing horsepower
I dunno I'm confusing myself, any help would be appreciated.:help
