elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Mon Aug 24, 2009 5:30 am
I just did a sunroof job on my Q...
There are 2 small clips that allow you to slide the interior panel back... You have to get at them with a screwdriver from inside the panel..
Once you slide that back, there are 4 nuts that hold the sunroof panel onto the track. You can raise/lower the sunroof by taking out a shim or 2. On mine on each corner there were about 5 really skinny shims that allow you adjust the height...
I have some pictures if you cant figure it out.. But the directions are in the FSM in the BF section and actually pretty detailed.
