skholla wrote:will i need a TPMS rebuild kit?
Schrader Bridgeport makes the TPMS sensors for Nissan and many other auto mfg's.
They recommend the grommet, retaining nut, valve core and valve cap be replaced every time the TPMS sensor is serviced/removed.
See more here:
http://www.schrader-bridgeport...d=111
A few more tips:
- Before the tire is dismounted from the rim, the tire must be deflated, the retaining nut removed and the TPMS sensor allowed to fall inside the tire. The tire can then be removed without damaging the sensor. Once the tire is off, the TPMS sensor can be retrieved.
- Upon re-installation, a new valve core, sealing grommet and retaining nut get installed along with the existing TPMS sensor.
- Finally, DO NOT use fancy chrome plated valve caps. Many are made from brass and will corrode where it comes in contact with the aluminum TPMS sensor valve stem. Once this happens, you will be lucky to get the valve stem cap off without destroying the sensor.
It's surprising simple how a small error can cost you hundreds of dollars in damage. The TPMS sensors are over $100/ea plus installation if you have to replace them.
