elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Fri Nov 30, 2012 6:37 pm
Really what you can do with it depends on the software. All that box is doing is converting the consult signal into something useful to a PC.. On the Z32 the o2 sensors are not like widebands, so you can't read AFR's with them like you might be hoping. Z32 o2 sensors are basically like ON/OFF switches or more like LEAN/RICH, and how often it switches from LEAN/RICH is how the ECU adjusts the fuel mixture (which on OBDI is mainly on cruising only).
