Consult connection '94 Q45 - Where is it?
goody90q45
Car: 1992 Infiniti Q45 (sold)
I went ot AutoZone today and borrowed their Consult (?) to read the check engine codes but could not find the connection under the hood. Where is it? I've been searching NICO posts for an hour now and can't find reference to it although I know I've seen it somewhere. FSM was not much help although I'm sure it's somewhere in the "bible".
Also, AutoZone only had the consult for OBD II. Is this the right one for a '94? Thanks in advance.
5seryan
Car: 1995 Q45t R.I.P.
Unfortunately for you the consult is useless for your needs. 1996 was the first year OBDII was put in the Q and if im not mistaken other cars. the only thing you can really do is run the self diagnostic.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Dealer or maybe an independent Z shop will have Consult I with correct cards.
goody90q45
Thanks. The Gentleman behind the counter thought that '95 might have been the first year but I looked anyway. I guess that explains why I couldnt find the plug.
I'll try and work my way through the FSM to pull the codes.
