TheOne »
https://forums.nicoclub.com/theone-u18820.html
Sat Sep 09, 2006 10:05 am
my friend and i used to use this airlink serial>usb cable, worked out pretty good(for being so cheap anywayz, you may want to get a better quality, as after sometime the solders came off the inside of the board, but the cable still worked just fine before), bought @ fry's electronics.
btw did you install the driver for your converter? usually these need drivers as sometimes xp doesn't have 1, also did you check which com port was it using and set it up on your consult software?.
