Consult and KA24E
doainwpg
I know that the SOHC 240 doesn't have a consult port and the ecu doesn't support it. however i was told before that you can use an ecu out of an early 90s stanza. supposedly it's a plug and play install. IS THIS TRUE?
ps. i know if this would work that i'ld have to wire in a consult port. I just want to know if i can use the stanza ecu.
Modified by doainwpg at 9:10 PM 10/10/2005
