Constructive Criticism Needed
Xero
I have designed, on paper, what I think to be a well designed KA-T. My only problem is, I don't have any hands on experience building cars, this is where you all come in. I don't want flaming about how this company sucks, don't buy their **** and stuff like that, I just want to know what I'm missing, and what I haven't taken into consideration.
I also want to know how reliable this will be, and how much boost I can run and power it should be pushing, just a rough estimate. I know you won't know how much power until it hits the dyno. I also know that this setup will need extensive chassis dyno tuning. This is just a plan, THANKS!!
N-Sport - Stage-I Turbo Kit Ceramic Coated Exhaust PartsElectric Fan UpgradeMSD - Complete Ignition UpgradeHKS - Hiper Series Cat-Back Exhaust Oil Cooler Differential CoolerClutch Masters - Aluminum Flywheel Stage-3 Performance ClutchCustom - Port & Polished Head Overbored Throttle Body Catch Tank Fuel Delivery SystemBosch - Fuel Pump(s)Apex'i - Boost Controller Turbo TimerRC Engineering - 500cc InjectorsUR - Underdrive PulleysMoroso - Custom Baffled Oil PanCusco - Chrome Oil Catch CanNISMO - Polyurethane Motormounts Oil Filter Movement KitHeat Wrapped ExhaustSS Oil & Fuel LinesWireloom Electrical WiresFluidyne - Performance Radiator UpgradeOE - S13 Silvia VLSD New Headgasket New Hoses
Xero
I forgot, there's no engine management listed there, because I'm still deciding what I want to run. I know someone running a SDS fuel management system, but I was looking at MoTeC. A chipped OE ECU will NEVER find it's way onto my car if it's turboed. EVER. not enough adjustablitity, I want two fuel maps, low boost, and high boost.
trpower7
Holy crap talk about $$..............
S13Ka24e
Car: Tunning, reading, learning
I don't know if guages come with N-Sport - Stage-I Turbo Kit but if is doesn't you will need them. You will probably need a larger radiator too. All else seems good.
Exar-Kun
Car: 2005 350Z
add a metal headgasket, uh..thats about all I can add to that, your list is similar to mine.
good luck man!-chet
Xero
yeah, I noticed that that list didn't have forged internals, but I'm being very indecisive. Turbo KA? SR20DET? Import a RHD Silvia? I don't really know. but thatnks. The gauges are on another list I have, I'm a list whore :) And the larger radiator is there.
NateDogg
go to http://www.sdsefi.com and read in their 'tech section' about hp and injector size.
