aesic »
https://forums.nicoclub.com/aesic-u30810.html
Thu Dec 22, 2005 9:33 pm
I wasn't exactly sure how to search for this so if someone could give me some suggestions or point me in the right direction I'd appreciate it.
My sub/amp constantly "thumps" at regular intervals. It is very annoying at normal volumes and is only masked when I turn up the volume and on the highway. The thumping does not change loudness or intervals when I rev the engine. However, I just figured out that the intervals between the thumping is a lot longer when the volume is very low, nearly inaudible.
Is this a grounding problem and if so, what isn't ground right? I removed the back seat (240sx) and have the amp in its place, ground to the bottom seatbelt bolt. The HU is currently not mounted in the brackets because I will be installing a DIN cupholder/change holder. Will mounting the HU on the brackets get rid of this thumping? Its just been sitting in the compartment for a while because I haven't had time to install the DIN cupholder and because I wanted to fix this problem before I get everything mounted. If it isn't the HU, are there any other suggestions? Thanks.
