Highway Q45 »
https://forums.nicoclub.com/highway-q45-u1500.html
Tue Sep 16, 2003 7:55 am
VenCountyQ-Thanks for the link to the nice clamp-on. I have to use both a low range and high range unit for my Fluke Scopemeter but the jaw size presents a problem in tight spaces. You are right though, I'm not looking at the problem from "how much" but "where". My 91, from the battery +, has a single large gauge to the starter and paired connector type 2-wires feeding the 100A and 120A fusible links. From there the 120A link shares a buss, one to the alternator I assume, and the other to the adjacent fuse/relay box. The 100A link also feeds the same box. Seeing how I'm too dense to figure out how to remove those links, I guess I'll do them one at a time by unscrewing the lugs or pulling the connectors at the positive battery terminal. It would sure help if someone knew the trick to pulling those links, there doesn't seem to be a latch and I'm afraid I'll break them if I keep pulling straight up.
Are the alternators or starters on the Gen1 Q's prone to failure? if they are it's new to me. It's still a lo-mileage car at 120K. I'm going to try a bootleg alternator test tonight. Problem is, a high-resistance short would still show decent charging if the short current was lower than the operational load on the alternator. In real world terms, a 4.25A draw is negligible for a high current alternator like the Q.
Now if I can find the open circuit resistance of the starter and alternator I might make some progress. It seems most of the testing in the manual is set up for a Consult and not the garage monkey like me.
The search goes on...thankfully there's 4 other cars here that WORK!
Steve
