console problems
NX123
Car: 2007 infiniti m35x
Hey everybody, I have a 2007 infiniti m35x and my console acting up. Like when I start the car it works fine then a couple of minutes everything shuts off the climate controls, radio, nav, and bluetooth. The only thing is working is the lights and the blower still blows but can't control it also the screen turns black and flickers. I check the fuses and they are okay. I also talk to my friend and he told me to get my hard drive need to be replace with another one and navigation antenna. I just want to get a second opinion before I do that. thank you an advance
EniGmA1987
Car: '06 Infiniti M35 Sport
When it is something this large of an electrical problem and the fuses check out ok already, I would just take it to the dealer to find out what the problem is.
NX123
Thanks dude for your advice. I had went down to the dealer but he told me that I need a new screen which will cost me a arm and a leg but my screen isn't damage. Idk I think he just want the money. Like my screen work it just it turn black every couple of minutes then the whole system turn off. Every time I get in the car the system works then in a couple of minutes later it shuts off. Idk Thanks again for your advice.
NX123
EniGmA1987 wrote:When it is something this large of an electrical problem and the fuses check out ok already, I would just take it to the dealer to find out what the problem is.
Thanks dude for your advice. I had went down to the dealer but he told me that I need a new screen which will cost me a arm and a leg but my screen isn't damage. Idk I think he just want the money. Like my screen work it just it turn black every couple of minutes then the whole system turn off. Every time I get in the car the system works then in a couple of minutes later it shuts off. Idk Thanks again for your advice. sorry for the double post still getting use to this site
EniGmA1987
If it worked every time for a few minutes before problems start happening and things shut off then it *could* be some sort of electronic chip overheating and shutting down. Which if that is the case it would be very bad and expensive still too...
Godfoot
Car: 1994 GCZ32 Fairlady-Z
1998 ER34 Skyline
1999 Infiniti Q45t
2004 Infiniti G35 Coupe
2006 Infiniti M45 Sport
1978 Datsun 280Z
1994 Toyota Supra MKIV Single Turbo
One thing to keep in mind my friend, just because the screen isn't visibly broken doesn't mean that I can't be causing the issue. All the controls and screen are wired up and work together, if there is some sort of issue (that may not be visible) with the screen, it could be causing issues with the functionality of the other components. I would not rule out the dealers assessment. However it maybe more cost effective to find a good quality used screen and try that. Just my 2 cents.
NX123
One thing to keep in mind my friend, just because the screen isn't visibly broken doesn't mean that I can't be causing the issue. All the controls and screen are wired up and work together, if there is some sort of issue (that may not be visible) with the screen, it could be causing issues with the functionality of the other components. I would not rule out the dealers assessment. However it maybe more cost effective to find a good quality used screen and try that. Just my 2 cents.[/quote]
Thanks dude I might get the screen replace but I got to see from a infiniti dealer first because I ask a nissan dealer and he didn't seem that bright. he compare my nav to a dvd player.
MOWellsinVA
Car: 2007 Infiniti M45 Sport (Obsidian Black w/ Graphite interior)
Well, the navigation system does use a DVD player to read the map disc.
NX123
MOWellsinVA wrote:Well, the navigation system does use a DVD player to read the map disc.
okay I will give it a try and replace the screen thanks everyone for your help wish me luck
JoshTex
Car: 2006 Infiniti M35
Do the gages go out as well? I just had an issue where I the whole dash and console did not work at all. Long story short is the fuse box had to be replaced. try tapping the fuse box, by your left foot and see if anything changes.
Larz
Car: 2019 Q70-L RWD
Dunno if this helps,but I was shopping for something else on Ebay and was able to find a few options for '2007 M NAV screen'. This one seem worth a try.
http://www.ebay.com/itm/2006-2007-INFIN ... 338wt_1175
NX123
Larz wrote:Dunno if this helps,but I was shopping for something else on Ebay and was able to find a few options for '2007 M NAV screen'. This one seem worth a try.
Thank you for helping me find the item
NX123
JoshTex wrote:Do the gages go out as well? I just had an issue where I the whole dash and console did not work at all. Long story short is the fuse box had to be replaced. try tapping the fuse box, by your left foot and see if anything changes.
Naw just the console and I check the fuse box next to my feet and everything seems okay
NX123
Update my console start working again for a bit then shut off then turn on for the rest of the day and everything works but the next day it start all over again I have second thought about the nav screen being replace I think it is an electrical problem idk
