nismoautoxr »
https://forums.nicoclub.com/nismoautoxr-u51726.html
Sun Mar 23, 2008 8:53 am
engine to anything rub translates to noise ,wear of the rubbing parts ,and vibration.Shim the sway bar center mounts to lower the bar,shim the mounts to raise the engine,heat and bend the bar to clear,clearance the pan to clear.Any one of many methods can easily be done to achieve clearance.If it aint right ,you know it aint right ,and it will continue to bother you.Fix it.Keep the bar.
Engine swaps can be done right or half assed.Which do you want to be?
Ricky-
