Jesda wrote:http://cgi.ebay.com/ebaymotors...sting
I'm in lust.
Will a Z31 be expensive to own/maintain? I drive a Q right now, which generally robs me blind ($7000 in two years). About how much do you guys spend annually on upkeep? Is there anything I should be aware of when looking for one? Are most things DIY?
Thanks!
Did you bid on that car? Cause if not, you're going to have a hard time locating a Z31 convertible. They aren't exactly items that are readily available. But they aren't any more expensive to own than a regular Z31.
WARNING: If you can't do the work yourself, you will be eaten alive in shop fees.
The parts aren't all that expensive (even from the dealership), but the labor rates are murder on your wallet. Remember, the Z31 is 15 years old at a minimum. And unless you find one that has been well cared for it's entire life (lots of documented upkeep), you're going to be working on a lot of things.
