c-rad »
https://forums.nicoclub.com/c-rad-u19918.html
Fri Jan 19, 2007 5:58 pm
I had never rebuilt a motor before when I did mine. The only thing that I didn't do myself was clean the head and block, bottom end assembly, and valve job on the head. All in all cost me about $300 at the machine shop. From there I did the rest and 5k miles later it still runs good so I must have done something right.
But in all seriousness, not to sound like a d!ck, but it doesn't sound like you can afford to do a swap right now. I would wait until you had enough money to cover anything that might pop up along the way. I probably spent close to $1000 more than I had initially expected when I picked up the motorset. Things add up FAST.
Oh, and to the person who suggested leaving the motor and transmission attached and not replacing the clutch. That's not a very good idea. If the clutch IS worn out (or at the leasted, rusted to hell) you don't want to find out when you start the car up and try and take it on its maiden voyage. That or having a cracked flywheel come apart and annihilate everything in the engine bay (and possibly your legs). Even if its a stock replacement clutch for $100 from the auto parts store, its better than taking a risk.
