Finally, a lot of none-so-diligent maintenance, I am in the process of tuning up the car. I have 103,000 on the odometer.
Have been doing a lot of things. I changed,
Air filters,
Spark plugs,
in the process of changing transmission fluid
I am considering putting Seafoam in brake booster vacuum line to clean up the engine. I also plan to put Marvel Mystery Oil or Kreen in crankcase just before changing the oil. I have a few questions about putting Seafoam in brake booster line.
Can someone confirm that I am pointing to the correct line with the red arrow? I need to open the clip and put Seafoam in black tube.
Any idea how much Seafoam I should put in there?
I just replaced my spark plugs last weekend with the new NGK OEM plugs. Will this treatment harm the plugs? I still have the old plugs so that I can put the old ones, run Seafoam and put the new ones back.
Thanks a lot in advance. Please comment if there is any chance of expecting the unexpected and any other advice.
