dyss wrote:hmm interesting.
yeah im looking to get to about 4-450 whp is my goal. i can already see F/I is already the cheaper route. have you found that N/A is more reliable though in the long run? i baby my cars so either route i take im taking extreme caution.
While its feasible, understand, that making more HP is generally a function of how much air you can pump through the engine. With NA, you will generally try and increase volumetric efficiency and/or increase redline as higher RPM's will pump more air through the motor. This is how Honda, BMW, and Ferrari are able to achieve 100HP/Liter figures on some of their motors. Making a high revving motor can be a challenge though. Especially with a motor that wasn't engineered with that in mind. Tensile forces on the bottom end become high. Balancing becomes more crucial. And trying to keep volumetric efficiency up in those higher revs is imperative. And if this is going to be a street motor, the latter can become quite difficult to achieve as the tendency is to lose low end VE as you increase high end VE.
If your goal is 400-450 WHP, we can assume about 450 HP at the crank minimum. That's 128 HP/L. The best Honda has been able to produce is 120HP/L in the S2000. And Honda has a slight advantage in that they can rely not only on variable cam timing to try and provide good VE throughout the rev range, but they can also change the lift. With the 07 Z, you have variable cam timing on both the intake and exhaust and that is a big plus, but typically, manufacturers have only been able to pull off about 100 HP/L without losing drivability. An extra 28 HP/L would be tough to pull off on a motor that is already being pushed to its limits. This will be getting into the realm of reengineering, which willl likely be expensive and beyond the knowledge and scope of most tuning shops.
I'd recommend a supercharger or Turbo. They can be bolted on or at worst, you rebuild the motor to handle the boost. This is relatively simple as it just adds stronger parts with the only real engineering being the decision of what compression ratio to run.
matt_2036 wrote:It is more reliable to a certain degree and a smoother power band.
N/A power that is well beyond the manufacturer's engineering is likely less reliable. Generally, adding boost to a motor add's only a moderate amount of additional stress. Most people kill motors due to detonation, which is either a result of poor tuning and/or the limitations of high compression coupled with the limitations on available gas. As for powerband, if by smoother, you mean flatter, then yes, NA can be smoother. If that's what you mean though, you might ask yourself what is better. "Smoother?" Or more powerful?
