In your S14, either turbo your KA or go rb25, the KA-T it's much faster less weight right out of the box, you can turbo your KA right for under 3k and put down 260 to wheels easy. I drive rb20 hatchs quite often, and they are slow until you upgrade the turbo and boost, and do some twekaing, FMIC and all. My turbo S14 is running 6psi, and does 231 to the wheels and 246 on the torque. I know the rb20 is cheaper, but from what I have heard their trannies crap out around 400. We upped the boost to a 12 psi run at the track a couple of weeks ago, and tweaked the fuel and timing a little more. And it ran a 7.95 in the 8th once we got finally got some traction, we borrowed some slick from a Cobra out there. For daily it's 6 for me though. I am selling my KA turbo setup to go with a RB25 because i have the money to blow on it, so it will be more comparable to my KA, but more potential in the long run, and plus the wow-factor. So if you do any swap you oughtta go RB25 or KA-T, as long as you have good compression your motor will be fine.
J.D.For Sale Full KA Turbo Setup
[email protected]http://www.e-emotorsports.com/turboka.php
