frapjap »
https://forums.nicoclub.com/frapjap-u17700.html
Sun Jan 05, 2014 11:48 am
Welcome to NICO, and welcome to Nissan again!
I'm not sure I can help you with the radiator issue aside from recommending that you replacing it with a more robust version before it has the opportunity to fail.
If Nissan did offer a fix, you'll find it by searching for a Technical Service Bulletin (TSB).
A good mechanic will find most typical problems such as leaks, tired suspension components, worn belts, brakes, etc.
I'm not familiar with the world of aftermarket warranties, but I suggest reading the fine print on all of them to be sure there isn't a point of no return that they will no longer cover the repair after a certain dollar value is met.
