Keyan »
https://forums.nicoclub.com/keyan-u106942.html
Tue Feb 09, 2010 6:48 am
I just traded in for a 2010 SR and it's a nice refinement even from the 2007 SE.
The CVT is great, esp when mated to the V6, and yes the warranty should cover you.
The Intelligent key does not unlock the doors when you get close or lock them when you walk away. You walk up to the car and push a little button on the door handle to lock/unlock the doors and there is a button on the trunk to open that. Alternatively you can push the buttons on the keyfob to lock/unlock/open trunk/wake up neighbors when you lean over just right and set off the panic mode. The car will not auto-lock when you walk away, you need to lock it yourself by pushing the lock button in the car, pushing the door handle button, or pressing the lock button on the key fob.
LATCH is not hard, however I did find that my particular car seat takes a lot of pressure and some wiggling to get it to fully ratchet down. This is more the seat though than the actual car, and the seat is now very secure.
As far as anything else, I really like the SR. The suspension has been changed slightly from the older SE - it is less rigidly stiff. The SE was so hard even stock that some bumps and rough road was jarring and honestly the car felt like it was unsorted to the point of having less control on rough roads. It was also almost jittery, it felt the road so much that there was almost a constant shaking in the car, even on smooth pavement (of course, that could also be the lingering tire balancing issue that the dealership was fighting the entire time I owned the car). That said, the SR is still great in maneuvering/cornering, with little body roll, so Nissan managed to find a good blend of stiffness in the corners and give over rougher pavement. Overall it just feels more refined. Not sure what you are looking for in terms of options, but the fully loaded features are extensive and things you would expect to find on luxury brand cars.
I would personally go with the 3.5 right out of the gate if the price difference is not a concern.
