Well I just had my J30s front struts replaced today with Z31 300ZX KYB struts. They needed some slight modding like the other people that posted installing these in order to make the swap.
Previous to these, I had replaced my front struts at @ 110,000 miles with FACTORY inserts from INFINITIPARTSUSA in Arizona. Currently I am at 151,000 so the last front set I got @ 40,000 miles out of. The struts were in very bad condition without any rebound at all. With the full strut assembly removed from the car, disassembled & strut cartridge removed from the tube, I pushed down on the strut cartridge & they did not return up, there was no rebound at all both left & right. Also both struts were leaking oil very badly. I was surprised to see these struts in such bad condition at 40,000 miles & was surprised the ride was not worse or that either was blown out completely. Also last time I replaced my struts at @110,000 miles I replaced the front tension rod bushings. 2 weeks ago upon inspection the driver side bushing was leaking fluid & the passenger side didn't look far behind, so I replaced both with solid polyurethane S14 or Z32 bushings (they are an exact fit). Now I will never have to worry about them again.
Just like these:
Once again this car rides GREAT.
I think before anyone orders FACTORY INFINITI J30 inserts they should consider that they probably have been sitting around for a very looooong time since the last J30 was made @ 15 years ago. I think this is part of the reason why my front struts were is such bad condition at 40,000 miles. It certainly wasn't because I was driving hard & abusing them. I also believe age was an issue with the tension rod bushing failing at 40,000.
Sooo... I am 2 "new car" payments in on my J30 again.
For those keeping track:
2 weeks ago: solid urethane front tension rod bushing installed
Today: both front struts replaced.
Up next:
KYB rear struts
A/C compressor
Driver side front window
Future considerations :
Strut tower bar
300ZX sway bars front & rear
300ZX caliper swap/upgrade
