HashiriyaS14 wrote:
So hang on, if some shop flushes it, and the trans dies, they're liable for replacing it? I would've guessed that I'd be SOL.
No, what im saying is that most shops who dont rebuild transmissions wont touch it due to liability issues. I have flushed and changed filter on a dodge pickup with over 150,000 and never been serviced, but the service manager made damn sure to note on the ticket and receipt that there is absolutely no liability or warranty and fully explained the consequences if something were to go wrong.
Your absolute best bet is to bring it to a transmission shop, like Cottman Transmissions (down here that is). They can tell you a whole lot more. And they can give u a price to rebuild/replace the transmission in case the fluid is bad looking enough. But, if you can take it to a qualified mechanic to at least give the fluid and running condition of the the transmission a once-over, you may be fine. If the fluid looks clean, no burnt smells, no leaks, then there is a possibility the previous owner(s) took care of it. But you are right, you have no idea.
Soooo.....If you cant afford to swap to a stick, cant afford to rebuild your current one, and can live with a little hesitation going from 1st to 2nd, i would leave well enough the hell alone and drive it till it breaks, cause flushing or replacing fluid right now is an unknown unknown . Either it will work or it wont. So my advice is leave it alone and drive it. Should last for a while.
