Well to quote the FSM exactly:
R32 All FSM wrote:RB26DETT/ RB20E DE DET/ CA18i/ RB25DE ENGINE
Compression gauge installation. Warm up the engine and remove all 6 sparkplugs.. Attach the adapter to the Allen compression gauge andset in a spark plug hole.
Compression pressure inspection' Depress the acceleration pedal fully. Turn the ignition switch to START position and crank the engine. Read compression pressure and the engine speed once the gauge needle stops moving.. When engine speed is out of specifications, check the specific gravity of the battery and perform test again if the battery is functioning properly.. lf the compression pressure is still not standard, inspect the components around the combustion chamber ( valves, valve seat, hydraulic valve lifters, piston rings, cylinde bore, cylinder head, cylinder head gasket etc.). Correct any malfunctions and repeat compression test.
It then further says the compression should be:RB26DETT should be 12.0 kg/cm^2 @ 300rpmand the RB20DET should be 12.0 kg/cm^2@ 300 rpm
and just incase you dont know what 12.0 kg/cm^2 is in PSI it is about 170.1 psi
